hey, ijust got a new cd player installed, and new rear speakers because 1 was shot, dont know what circuitcity did, there is loud clicking noise coming over my speakers and makes a weird noise when i give the car gas, never did this before, they said its because my powercord to my amp is running along my rca wires, and that my new cd player is stronger, so i moved to powercord to the other side no where near the rca wires and it still does the same thing? what do u think is wrong?
check your grounds......most likely that!!! and what deck are you using
circuitcity did check the ground, they said the cord was a little long for a ground, and i have a Pioneer
Step 1.
Unplug the RCAs, see if the sound is still there.
Step 2.
Take a piece of wire, strip the end and screw it on to the ground post of the amp.
Strip the other end of the wire about 3 inches, wrap the bare wire around both the RCA plugs and plug the RCAs in over them.
Step 3.
Check the ground. The paint should be scraped off where the ground connects to the body, and it should be tight and secure.
Step 4.
Post results
Step five: If all else fails, move your RCAs, reground in a closer location, and run the ground on your radio wiring harness directly to the negative post on your battery. It's amazing how much we worry about the power cables to our power amps when in theory our head units are amps themselves =P
There's a thin line to be crossed, when the upgrades to your vehicle increase your chance to get tickets by an amount exponential enough to stop worrying and build the fastest, loudest car you can.
there saying now it may be my ultinator, had it tested said it was going out, any body know if that could be doing it?
did you even try to ground your rcas
i bet you 90% that is the problem
