I have a new radio problem that i have never ran into before. Any ideas would be great..
When the car is runing there are no problems what so ever.
When the car is on accessory or run the radio shuts off and restarts if i turn it up past half way. I have never had that problem before. Any idead what it could be?
Perhaps the radio is especially voltage sensitive, or perhaps your battery is getting tired and needs the alternator to properly supply the radio. Voltage tends to be quite a bit lower without the engine running, but too much can cause problems.
Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
Only time I ever had this problem was when I had a POS Sony Xplod head unit. I since upgraded to a Pioneer Premier with no problems whatsoever. Any money its the HU.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
I hope my HU isnt going out.. Was freaking almost 700 bux...... And it works fine when the car is running
What kind of HU are you running?
1997 GMC Sierra
2005 Honda TRX450R
check the voltage on the battery when you have the stereo on.
check your ground as well. Sounds like it isn't getting enough voltage.
Well today i polished the valve cover... Thats besides the point but after having my radio on for about 5 minutes i touch the negative terminal on the battery and burn myself... Not good. What gives? Do i have a bad ground somewhere?
check your battery's grounding cable and your amp's ground...
'03 Cavalier
DesertTuners.com
That hot was excessive current draw through your ground. You also might have a short in the battery itself. I agree with most, check the voltage of you battery, and then make sure your ground is good.
AMERICONIUM (Adbot Rocks) wrote:That hot was excessive current draw through your ground. You also might have a short in the battery itself. I agree with most, check the voltage of you battery, and then make sure your ground is good.
x2
It obviously isn't the HU after what u said happened. Def. check the batt and grounds.
1997 GMC Sierra
2005 Honda TRX450R
Voltage is love at 11.17 with car sitting...
Voltage drop from negative termal to ground was 1.43 volts WOW HIGHT Should be less then .1. Fixed that. Still have a problem with the head unit turing off. I think its time for a new optima red top. Mine is almost 5 years old!
