get an amp that puts out 1000WRMS at 1ohm
that you can afford
I'm talking about headroom here. The subs would only be wired down to 2ohms too you might have noticed.
I understand headroom and room to upgrade later on, but if the guy is on a budget enough to not be looking at higher end subs, why spend the money on an amp with 4 times the power he needs? 250-400 RMS at 2ohms is easy as hell to find cheap as dirt.
In my family we teach that boys have a God-stick and girls have a Shame Cave. -John Stewart
you can only get 400 watts with that amp....look for something between 800 - 1000 watts rms at 2 ohms..
alpine amp
It says 800 rms bridged though...i dont fully understand what bridged means.
well if you are only getting one sub bridging doesn't even apply to you
It completely applies.
Bridging is when you take both channels of a two channel amp and 'combine' them by using the + of one channel and the - of the other. (usually, the amp will tell you how to wire it)
If you're running one sub off a two channel amp, then yes, you are concerned with the bridged rating.
bradsk88 wrote:Quote:
actually you are both right and wrong....if that makes any sense. Reason i say this is because for the OP it doesn't apply because hes using a 4ohm DVC sub..which he will not be able to bridge....but brad did properly explain what bridging means....oh and if he had a SVC 4ohm sub then it would apply...
I stand by my original statement.
Sending two channels to two different coils in the same driver is a bad idea
oh I misread what you posted. You're right, he won't be able to bridge it unless he gets a 2ohm DVC or a 4ohm SVC OR a 2ohm bridgeable amp.
I was about to come in here and wreack havoc about illd's comment.... But then I realized I was misunderstanding the same thing you were, brad. LOL
ahh, I understand now, bridging seems more complex then I had thought. So to power this 12" I need an amp that can put out 800 rms or more at 2 ohms. correct?
