does this car have factory alarm?? - Audio & Electronics Forum
Tuesday, September 16, 2008 3:53 PM
ok so I recently aquired a 98 cavalier sedan 2200 3speed auto. Has power door locks/manual windows, and a fuse in the fuse spot for the factory alarm, but owner only gave me one regular key for the car. So does this mean it has the factory alarm and I can buy a remote at the dealer to work it, or do all these older cavs have the fuse/spot for it either way?? JW, would be nice to not have to install an aftermarket alarm like on my 05.
Oh, want to know this for a buddy too he bought a 99 BASE model with an alarm slot as well and same thing just one regular key from previous owner.
Re: does this car have factory alarm??
Tuesday, September 16, 2008 7:26 PM
Drivers side in the trunk behind the carpet there will be a little black box with about 15 wires coming out of it if you have factory keyless. If you do, all you need is a replacement keyfob. then you program it.
Remote programming can be found here.
Keyless Entry Remote Programming
My Cardomain Page
Tuesday, September 16, 2008 8:39 PM
thanks ill check into it.
Tuesday, September 16, 2008 8:45 PM
roll down the windows,
lock it with the fob,
leave it for ten,
open the door without the key
alarm go off? answer= yes
nothing? answer= no
Tuesday, September 16, 2008 10:03 PM
problem is, if it goes off, how am i going to shut it off without a remote? lol minus disconecting the battery wich might not work so well.
Tuesday, September 16, 2008 10:07 PM
often, you just put the key in the door and turn it back and forth
Tuesday, September 16, 2008 10:17 PM
only car thats ever worked on that ive seen was a diamante, not a j, but idk maybe im wrong thanks for your ideas though, im just scared it wont shut off lol
Tuesday, September 16, 2008 10:23 PM
I work in an install bay, we do these all the time.
If it does go off and the door trick doesn't work, it'll turn off by itself after a minute or two
Tuesday, September 16, 2008 10:52 PM
also why would it have an alarm fuse if it didnt have an alarm, doesnt make much sense to me, I would hink it would have to have an alarm, but ive had the battery disconected multiple times etc, never had an alarm go off, and when I lock the door by the key or switch on the door the headlights dont flash etc. think ill try that idea tomorrow though.
Tuesday, September 16, 2008 11:03 PM
It's possible that they just got a new door for the fuse panel and just filled in the blanks, even though no circuit might even be there.
Wednesday, September 17, 2008 3:51 AM
theres metal contacts behind the 10amp fuse in that spot.
Wednesday, September 17, 2008 4:54 PM
did you check behind the trunk carpet yet. on the drivers side. my 96 cavy sedan has factory keyless. i just dont use it. i have an aftermarket alarm.
Wednesday, September 17, 2008 8:04 PM
yes, I checked this morning, no box underneath the carpet in the trunk, so I guess no alarm and no keyless entry just power door locks
Wednesday, September 17, 2008 8:18 PM
yepp
