wasn't sure which forum to go with, so I figured here.. if I'm wrong, dont linch me
so as the topic says, when I hit my blinkers, they dont do that.. they just stay solid. I had a cheap set of LEDs in there that kept goin out, so I tossed them for a set of normal replacements bulbs, thinkin that'd fix the problem, but nope.. I checked the fuses as well, but they're all good.. I dunno if there are relays to check or what, so any help would be much appreciated
R.I.P. JessE Gerard 7.11.87 - 1.25.08
The Radiation Nation Facebook Twitter Twisted Metal Alliance
bad flasher. its above the brake pedal, stock one is green, and costs $16 at any parts store. BUT, if you want to go back to leds, superbrightleds.com, PN EP27L is designed to be used either with leds or incandescent bulbs, and eliminates the fast blink that is caused by a led bulb not drawing enough to cause a standard flasher to notice its there. and, it costs about the same as a stock flasher after shipping. dont use load stabilizers, it's a band-aid fix and can cause fires.
car audio noob since 1984.
you mean that green relay box? that things been just danglin down for the last almost 2 yrs (I mounted it wrong after my ECO swap).. it kinda gets kicked around since its right on top of my gas pedal usually..
Also, the bulbs have dual filaments, and if they cross (it happens, believe me) this will happen too.
