wiring 2 amps - Audio & Electronics Forum
wiring 2 amps
Monday, June 09, 2008 7:06 PM
I have 2 kicker 12 inch L7's and they rms at 750 watts...so i bought 2 kicker zx 750.1 amps and i plan to wire an amp to each sub....how do i need to wire them for the sub to get all of the power from the amp...the subs are D2
Re: wiring 2 amps
Monday, June 09, 2008 8:08 PM
you cant. you can get 375 at 4 ohms from each amp but you wont be able to get 750 cuz they arent 1 ohm stable
"I did it because I wanted to see what it would look like. You should be greatful that I even told you that it would look good. If your to dumb to use photoshop and change the color of your own car then you don't need to see it changed. I'm not going to give my work away. I'll sell the pic to you though for $15."-Adam Kalin
^^JBO is about not being that guy
Re: wiring 2 amps
Monday, June 09, 2008 11:16 PM
looks like you got the wrong amps...you should return em and get an amp that pushes about 1300 watts at 2 ohms...then you should be good
Re: wiring 2 amps
Tuesday, June 10, 2008 9:25 AM
get the kicker 1500.1 and youll be set, youll be able to wire your subs to two ohms, power the subs well, and use only one amp
Re: wiring 2 amps
Tuesday, June 10, 2008 8:24 PM
well if i cant get 750 to one sub out of a zx 750.1 how can i get 750 to each sub using just one zx 1500.1?
Re: wiring 2 amps
Tuesday, June 10, 2008 8:33 PM
with 2 subs that are DVC 2 ohm you can wire the subs together at 2 ohms. the zx1500.1 puts out 1500W RMS at 2 ohms. so each sub would be getting 750 Watts of that 1500 W
Re: wiring 2 amps
Wednesday, June 11, 2008 6:47 PM
i'd like to know more about this topic too. I plan on running two amps, i have one on a Cerwin Vega Subwoofer Right now. And i would like to run another amp to some front components. how do i go about this?
2000 Cavalier Sedan.
Re: wiring 2 amps
Thursday, June 12, 2008 11:28 AM
if you guys looked in your instalation manual that the amps come with there is probably a diagram.... could be wrong but i know mine all did.
Re: wiring 2 amps
Thursday, June 12, 2008 7:12 PM
heh, problem is that. I plan on running some MB Quart Components in the front and Keeping my 1000 watt for two Cerwin Vega 12"s. So i need to figure out how to wire up 2 amps so i can power both. And about the tweeters that they come with, just get a hole saw and pop a hole in a larger part of the door?
Re: wiring 2 amps
Thursday, June 12, 2008 8:15 PM
you wire the amps the same way you would if you were running just one. run remote, power, and rcas to each. ground to bare metal on body. set gains and done. its not rocket science
Re: wiring 2 amps
Thursday, June 12, 2008 9:09 PM
just remember you gotta have a headunit with dual rca jacks, or run a splitter
