I have a 98 fog light panel and am trying to hook it up to my aftermarket fogs.. The switch has 3 wires.. Anyone know where each one is suppose to go?
http://www.jbodytuner.com
^^ The real jbody store!!!!!
What you will need to get a test light or voltage meter, Test out what wires have power going to them. I believe their should be 12 volt straight power source, Then accessories igintion wire that allows lights to turn off when the key is turned off. Last wire should be a ground wire.
Good Luck.
Thanks I will try it sometime.
