power lock problems - Audio & Electronics Forum
power lock problems
Monday, April 28, 2008 3:48 PM
strat81 Online
the powerlocks in my sedan are acting up.
recently, if you hit the unlock button the first time, it will unlock the driver's side door (like it should) but if you hit it again, the rest of the doors do NOT unlock. Also, when you press the lock button, none of the doors lock. if you hit the lock button a 2nd time, you get the horn chirp but still the doors do not lock.
any ideas on this?
everything else works (trunk, panic)
Re: power lock problems
Monday, April 28, 2008 4:04 PM
I have the same exact problem with mine..it's been going on for about for about 6 months..never found an answer..listening in..
Monday, April 28, 2008 4:13 PM
Monday, April 28, 2008 4:49 PM
THAT WAS IT!!!! There was a mir/dlc fuses that was fine...but another fuse under there labeled apo was blown..everything works fine..you should take a look at it..
Thursday, May 22, 2008 2:56 PM
strat81 Online
checked all fuses... none of them look to be blown.
i'll check the apo fuse and replace it for good measure though.
