check it, know how to do the big 3 and whats its for ect....... my question is whats the easiest way to get to the positive on the alternator on the ecotec? it seems like its almost impossible with out taking the alternator out. I did the grounds already and it helped a little but i need too hook up the positive becuase my lights still dim and i dont want to kill my alternator.....doesnt look like fun to change. Any help would be great! I know a 4 guage wire is rated for about 125 amps but is a 100 amp fuse good enough? i got the wire ready to go....
I have a 100 amp fuse on mine (4ga) and it works fine. Im only running a 1000w amp and have never turned it all the way up.
I have a 2200 however, and couldnt tell you what to do about the physical running of the wire however. Good luck with it! It helps a TON.
Just attach it where the positive goes to the starter. Thats really the only way. Its not as good as a direct connection but its better than going via the engine wiring harness.
-Chris
thanks sndsgood ill try that, last night i noticed when my friend opened my door (music was very low) and i had my hazards on my damn dome light was blinking with my hazards!! I think my alternator is going.....i really need to do this upgrade...lol
yep, crawl underneath and do it. much easier then from up above.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
thanks guys im actually off tomowrow so im gonna try and do it at the install bay at my job....i just gotta get a hold of a fuse holder and a 100 amp fuse.....
