is the main ECU?
i've found 3 boxes that could be it....
one is on the passengers side, behind the front bumper kinda under the lights (8x8 about)
one is under all the dash, right behind the fuse box (about 6x6) and one was wrapped in a blanket like thing right above that (3x2)
the 3x2 might be for an aftermarket security system on the car, but what do the other ones do?
the one under the headlights says "DELPHI" on it and the other one under that dash (6x6) is to hard to access to even look at.
Mike wrote:The auto to manual swap is not as involved as you would think.
Get all the parts you need in a pile, and drive the car into it.
They will find their way into the correct places.
thats the one.
car audio noob since 1984.
Under the dash, on the driver's side... against the A-pillar, there's the body control module (BCM) which is a black box 5.75" x 4" and about 1.5" thick. There's three connectors on it, one is light blue, one is brown and one is purple. It has a white sticker on the front face, which says "Delphi Automotive Systems" along the top, and "BCM" or "BCM/RFA" if you have factory keyless entry.
Not sure on the "blanket wrapped" one. Might be something aftermarket...
...j
