how do u take the 6x9's out of a 96 cavalier bc their is some housing over them?
Ok dude...I had to jump on GM service information...(dads a tech) neways.. you HAVE to take out the rear quarter interior panel...at least one..don't forget you have the coathanger and the saftey bolt on the seat belt. I think it is a #47 Torqs also the seat and back have to come out. I wouldn't recommend putting the replacements back in the stock place..I screwed mine to the bottom of the rear deck plate..works fine. Also...on the rear seat..on the passenger side there is a small clip that has to be removed before the seat can come out...DO NOT..I repeat DO NOT try to take out the rear deck plate without removing the interior quarter panel...you WILL break something.
RedlineZ wrote:Ok dude...I had to jump on GM service information...(dads a tech) neways.. you HAVE to take out the rear quarter interior panel...at least one..don't forget you have the coathanger and the saftey bolt on the seat belt. I think it is a #47 Torqs also the seat and back have to come out. I wouldn't recommend putting the replacements back in the stock place..I screwed mine to the bottom of the rear deck plate..works fine. Also...on the rear seat..on the passenger side there is a small clip that has to be removed before the seat can come out...DO NOT..I repeat DO NOT try to take out the rear deck plate without removing the interior quarter panel...you WILL break something.
i did not remove the interior 1/4's and did not break a dammn thing
^^ +1. changed my rear 6x9's twice (blew two sets of factory speakers) and i've NEVER had my rear quarters out or broken anything.hell i never even took the top carpet completely off... just bent it a little, then bent it back.
car audio noob since 1984.
well if you guys wanna do that @!#$ thats fine..I just don't want to drive around in a piece of @!#$..thats all. BTW..that info came straight from S.I. so kiss my A$$...it only takes a little more time and it gets the job done right instead of half done.
Redline i hope you know those procedures can and are short-cutted. Your dad's a tech(so you claim), you should know that. I didnt remove my panels when i did my 6x9s and it doesnt look like @!#$
