Hey guys, i did a search but couldnt quite find what i needed. I am looking to build a false floor in my 97 cav. I took out the stock carpeting and dont really want to put it back in, so my exsisiting system tends to slide around and is now extremely ghetto rigged with bungee cords. this take away from my cars tasteful outter apperance
needs fixing. so i wanted to build a false floor to mount the amp, capacitor and sub box. I am not sure how to get started, i dont want anything fancy, just a basic design! any ideas are welcome or insight on how to do this! thank you!
i used to have a GP going for the false floor templates. i still have templates available if interested. how high are you looking to have the false floor rise up from the stock floor?
not very high, maybe 5-6 inches. I just need something to stop everything from sliding and have something to mount everything properly and have it look tasteful at the same time. anything is better than bungee chords....not very proud of it currently
i have baggs template still waiting to put it to use though,
jason
You could always make your own template using cardboard. It's kind of a PITA, but cardboard is stiff, and alot easier (and cheaper) to cut and manipulate than MDF.
GAM (The Kilted One) wrote: if you think you're that much better than them because you're "correct" I hope your progeny don't turn out as screwed up as yourself.
Yeah i thought about the cardboard and it really will be a PITA . Baggs, how much would a template run me?
Just secure everything down. Use velcro, allthread, whatever.
unoath wrote:Yeah i thought about the cardboard and it really will be a PITA . Baggs, how much would a template run me?
I need to do the same thing...How much for a template? And how high off the floor does it work for?
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
if it slides aroun d it means your system isnt heavy enough.
What are you trying to template out? trunk or back seat area
trunk
1997 GMC Sierra
2005 Honda TRX450R
using cardboard isn't very hard to do, don't be so lazy.
make a template of each side, then tape them all together and take them out. trace and cut
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
if you guys are interested in a template...shoot me a PM.
but for all my temlates i build, i piece together pieces of cardboard...tape them together to get all the little angles needed in the corners etc.....
then take the taped together template and trace it to a one sheet template. refit...trim as necessary and then transfer to MDF.
thats basically the process i use..in a nutshell
do u cut the wood and everything for us? or u just draw it out and let us use it?
I'm interested in one of these templates. I PM'd you, but haven't received a response. If someone could help me out that'd be great...
Yea, I already looked through that. I'm basically just looking for some measurements or a template in the shape of the trunk that I could just copy. I'm not really looking to fiberglass like that...
I have pictured how to make the template from cardboard, cut it out of wood, and cut out the locations for amps and subs.
One thing to keep in mind; if someone does give you a template premade for the floor, it will not be the exact shapes 5-6" up the walls - so you will have gaps, and it may be above the latch so you would have to build in that gap too. It depends on how nice you want the finished product to look.
^CLICK ME TO SEE HOW I BUILT EVERYTHING^ How To in Interior Forum
Well I was just hoping that someone already did have a pre-made cardboard cutout that I could use. It would just make the whole process a lot easier. Even if it did need some minor changes here and there...
