I want to keep my setup hidden in the trunk, but for the LOC should keep it colse the the HU and run longer RCA's or in the trunk and extend the frint speaker wires to the rear with short RCA's. just curious as to if different wire lengths played a role in sound quality, and i will be gettin a new HU after I move outta here.
Kill list:03 eclipse, 06 GTO, 04 Mach 1 Mustang
personally, i would place the line output convertor in the trunk and run a shorter RCA. if you plan on keeping the system hiden and such, you will probably have more room to hide the LOC in the trunk and also it will make the install much easier as you dont have to run RCAs the length of the car now. you can tap the lines for the rear speakers for the inputs into the LOC.
1997 Cavalier Z24 - 16.3 in 1320 and falling...
I would run rca's just because it would help to keep noise out of the system
if your planning on upgrading your hu, put it by the hu, ust so that you wont have to run new wires when you do get he new hu.... youll have a little noise but when you get the hu youll thank me.
"I did it because I wanted to see what it would look like. You should be greatful that I even told you that it would look good. If your to dumb to use photoshop and change the color of your own car then you don't need to see it changed. I'm not going to give my work away. I'll sell the pic to you though for $15."-Adam Kalin
^^JBO is about not being that guy
steven c. wrote:I would run rca's just because it would help to keep noise out of the system
You still need to run RCA's. its possible your thinking of a high level connection for the input to the amp.
Chris Rogerson wrote:if your planning on upgrading your hu, put it by the hu, ust so that you wont have to run new wires when you do get he new hu.... youll have a little noise but when you get the hu youll thank me.
if you attach the LOC to the rear speaker wires, it wont matter if you change the head unit unless you dont wire in the rear speakers to the radio harness.
thanks for the info, and sorry for got to mention that im ampin my front speakers and kicks so ill keep the LOC up front hidden somewhere
If your getting a new head unit why not just use the rca outputs on it? they are higher voltage than what a loc can provide (most)
i was just meaning that if he keeps it near his current headunit he can just rmove the LOC and plug them into the new hu when he upgrades rather than having to run all new rca wires to the hu when he upgrades.
steven c. wrote:If your getting a new head unit why not just use the rca outputs on it? they are higher voltage than what a loc can provide (most)
I'm livin in a crapy neighborhood and had my radio and tv stolen so im waitin till i move out to get another HU, which well be in the summer or fall
Chris Rogerson wrote:i was just meaning that if he keeps it near his current headunit he can just rmove the LOC and plug them into the new hu when he upgrades rather than having to run all new rca wires to the hu when he upgrades.
good point, and i want to minimize any interfearence as much as possible
