i have a 2004 sunfire im getting an after market cd player and door speakers and rears, i dont give 2 @!#$s about a door chime and i do not! want to pay 100+ dollars for the aftermarket harness, ive heard you can use 00+ geo tracker harness, can anyone confirm this? i dont mind splicing and soldering into the stock harness if i can get the color codes for the wires i dont find much on 2004 pontiac sunfires only older ones or cavis
thanks all
you can make your own harness for about 20-25 dollars if all else fails, ill show you how on my
build thread monday.
yes geo tracker harness will do it
Or you can go to walmart pick up the gm-035 harness for ~$8 and run a acc wire from your fuse box to the harness
steven c. wrote:Or you can go to walmart pick up the gm-035 harness for ~$8 and run a acc wire from your fuse box to the harness
thats easy enough does this kit come with a antenna converter?
