Ok so today i turn my cd player on and think hmm i have no bass thats strange, i check the settings on the stereo and they are all fine so i go check the sub and amp, my sub is not on and my amp is not on? and there are no lights at all on, on the amp. I've checked the fuses, connections etc but they all seem ok.
Its only a small system running like 200watts i think.
The amp is an MTX RT202.
All i can think is i have somehow blown the amp? Any ideas what is wrong or should i just take it back and get it exchanged for a new one and see what happens?
I had been having a real good day up until then.
Thanks in advance guys.
(99 - Sunfire - Red - 2200)(95 - Cavalier z24 - Purple - 2.3 quad four)
check the remote?
car audio noob since 1984.
Yeah, I'd start by grabbing a volt tester and making sure you have power on the power and remote wires. If those check out, I'd start wondering if the amp has given up the ghost.
Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
Sounds like remote to me. Did you wire it to the head unit? Mine is in the ignition fuse so I don't have to remove the dash to check it out!
i've got the same problem, but i cant afford a multi meter at the moment. can i take some left over wire and connect it from the remote on my amp, and then touch it to the bat. pos. to see if that makes it turn on?
Listen F***ers. FASTERTHANAHONDA is a joke because I WORK FOR HONDA. I'll talk @!#$ about Fords to, that doesn't mean I can beat a 12 second mustang.
you can buy a 10 dollar one at walmart..it will work for what you want to do with it...
So there should be power running from the remote wire to the amp? If not does this mean my amp has given up?
Yes the remote is wired into the head unit, I've checked and re-connected it but still nothing. I shall be taking it back tomorrow if i cant fix it and hopefully have a new one.
moneys that tight. can i do that or is that to much of a direct link?
i also have the mtx rt202. the power light on mine comes on if i have the rcas connected to both the amplifier and the hu and even minute power from the battery. the light gets brighter when the stereo is turned on and the remote is thus powered. the only way that the power light is completely off is if the rcas are not properly connected at both ends, the positive from the battery is interrupted, and/or the amplifier has indeed "given up".
"I did it because I wanted to see what it would look like. You should be greatful that I even told you that it would look good. If your to dumb to use photoshop and change the color of your own car then you don't need to see it changed. I'm not going to give my work away. I'll sell the pic to you though for $15."-Adam Kalin
^^JBO is about not being that guy
I would check the power to the remote, the power and I would also check to make sure you have a good ground. Then I would go from there. If it is not working then I would check your RCA's.
