I currently have 2 audiobahn aw1200v subs and i wnat to add a 3rd one.. what woudl be the best set up for those subs? 3 seperate amps 1 for each sub?? also i would assume i need to upgrade to 0 gauge wire but not sure.. im not realy sure on the whole stereo stuff so any help wodl be appreciated
it would be easiest to have one amp but you would have a weird coil configuration. Three amps is more pricey though.
ya im not to worried about price ijsut want the most power out of them tho that i can get... guess i was lookin more of what amp i shoudl be using for them..thanks for the input so far
I'd recommend at least an 800w 2 ohm stable single channel amp
that amp would be fine at a 2.6 ohm conf. you would be pushing just over 700
![](http://registry.gmenthusiast.com/images/jumble/MATTS%20CAR%20004.jpg)
PPPSSSS!!!! MMMMMmmmMMM boost=yummy
which one u mean the 800? then just get 1 for each sub?
Those subs are only 750 RMS, and the amp is RMS rated @ 800, you'd be overdriving your subs.
If you want to wire multiple amps, go for it, but 1 of those will drive all 3 subs @ 800 watts total.
