ho do i run 2 amps? - Audio & Electronics Forum
ho do i run 2 amps?
Friday, November 16, 2007 1:17 PM
hey
i m trying to figure out how to run 2 amps ? i am running a 600 watt mtx 2 channel amp for my subs and i have a 4 channel amp there to run my pioneers front and back but no clue how to to hook up that 4 channel
HELP PLEASE !
let me know guys what do i need and so on ..
Re: ho do i run 2 amps?
Friday, November 16, 2007 1:59 PM
Use a distribution block for your power wire, ground tothe chassis, run your remote wire to a but connector and split it off to both amps, and get a 4-channel RCA cable.
Your headunit may have enough RCA outputs for both amps, or you can do what I did,get a 5-band equilizer which has spaces for 4 amps on he back and you get the added adjustability.
Sunday, November 18, 2007 8:50 AM
If your cd player has sub outs and front/rear outputs, then you can run them as is.
If not, Your amp should have an RCA output on it, you can run the signal from the 4ch. to the sub amp that way.
everything else is straightforward. A fused distribution block will allow you to power both amps. Ground them both to the chassis. and split your remote however is easiest for you. Either at the crimp, or jump it from one amp to the next.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Tuesday, November 20, 2007 6:36 AM
RCA y splitters and distribution blocks for the wiggidy win! Depending on the # of amps you're running you might want to put a relay on your remote turnon lead.
