ok im having some problems with the lights flickering and dont know what i need and also my jlamp keeps getting reallly hot!!!...I have 2 guage to the cap and 4 guage to the amps....this is what i have so far
Radio
Technical Information
Media Support
USB Flash Drive
Secure Digital (SD)
CD-R
CD-RW
Formats Support
MP3
WMA
CD-DA
Display & Graphics
Display
LCD
Display Features
ID3 Tag display for your MP3/WMA files that have ID3 information available.
Audio
Output Power
180W
Equalizer Modes
Pop
Rock
Classic
Flat
Tuner
Tuner
AM
FM
Station Presets
30
Interfaces/Ports
Interfaces/Ports
USB
3.5mm - Stereo Audio Line In
Miscellaneous
Package Contents
VR3 CD Player
3.5mm Audio Cable
Instruction Manual
Additional Information
English, Spanish Instruction Manual
Stereo/AUX Input
4 Speaker Channels
2 Channel RCA Preamp Outputs
180 Watts Total Maximum Power (4x45 Watts)
4 X 21 Watts RMS
Electronic Detachable Face Plate
4x6 and 6x9 speakers
Alpine type-s 4x6s
Description: Alpine SPS-46C2 4" x 6" Coaxial 2-Way Speaker features Peak Power Handling: 150W, 3/4" Silk Soft Dome Tweeter, Aluminum Coated Polypropylene Cone Woofer, Frequency Response: 50Hz - 30kHz, Mounting Depth: 1-39/64"
Alpine Type-R 6x9s
Sensitivity: 89dB / W(1m)
Impedence: 4 Ohms
Frequency Response: 60Hz - 27kHz
Power Handling
Power Handling Capacity (Peak): 200 Watts
CEA-2031 Power Rating: 100 Watts
Inside speaker Amp
Alpine MRP-F450
4-channel V-Power amplifier (bridgeable into 3 or 2 channels)
RMS Power (at 14.4V THD+N, 20Hz-20kHz)
Per channel into 4 ohms: 70W x 4 (0.08% THD)
Per channel into 2 ohms: 140W x 4
Brigded 4 ohms: 350W x 2 (0.3% THD)
Bass Engine¨ Sound Tuning
Crossover Frequency : 50Hz - 400Hz HP/LP/Off(-12dB/oct)
Subsonic Filter (Fixed): 15Hz
Bass EQ Frequency (Fixed): 50Hz +12dB (Ch3/4) On/Off
Dimensions
Heat Sink (WxHxD) in: 11-15/64" x 9-31/64" x 2-23/64"
Heat Sink (WxHxD) mm: 285mm x 241mm x 60mm
Foot Print (WxHxD) in: 13" x 9-31/64" x 2-23/64"
Foot Print (WxHxD) mm: 332mm x 241mm x 60mm
General
Power Requirements: 14.4V DC (11V to 16V)
Fuse Type: 30A x 2
Frequency Response: 10Hz - 50kHz (+0,-1dB)
Signal to Noise (S/N): 100dBA (Reference to Rated Power)
Input Sensitivity (For Rated Power): 0.2V to 4.0V (1.0 at Center Detent)
Input Impedance: 10k Ohm
Speaker Impedance: 4 or 2 ohm Bridged
Weight: 3.3 Kg.
SUB
Free Air Resonance (Fs): 30.6 Hz
Electrical “Q” (Qes): 0.578
Mechanical “Q” (Qms): 7.647
Total Speaker “Q” (Qts): 0.537
Equivalent Compliance (Vas): 1.28 cu. ft. / 36.1 liters
One-Way, Linear Excursion (Xmax)*: 0.9 in. / 23 mm
Reference Efficiency (no): 0.171%
Efficiency (1W/1m)**: 84.3 dB SPL
Effective Piston Area (Sd): 59.8 sq. in. / 0.0386 sq. m.
DC Resistance (Re): 2.75 ohm
Nominal Impedance (Znom): 3 ohm
Thermal Power Handling (Pt): 500W
Driver Displacement: 0.09 cu. ft. / 2.5 liters
Net Weight: 30 lbs. / 13.6 kg
SUB AMP
JL Audio 500/1v2
Description: Class D Monoblock Subwoofer Amplifier
Rated Power: 500 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
340 mm x 235 mm x 60 mm
Patented Technology: High-Damping Class D Circuit with discrete control circuitry (U.S. Patent #6,441,685)
Differential-Balanced Input Topology: 1 pair of inputs
On-board Crossover: Fully-variable (40-200 Hz), selectable-slope (12 or 24 dB per octave) LP
Preamp Output: 2-channel (independent active filter, parallel with amp filter or pass through)
Bass EQ: Single-band parametric with variable boost up to +15dB and Remote Bass Option
Infrasonic Filter: Fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: Permits operation without remote lead
Dual mono speaker output connections: Accept up to 8 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
Cap
Audiobahn Capacitor
1 FARAD DIGITAL CAPACITOR W/ DISTRIBUTION BLOCK TERMINALS
1 Farad Capacity
24 Volt Rated - 30 Volt Surge
Auto on / off Blue 45° Four-Digit Readout
Blue LED Indicator Light
Electronic Polarity Protection Circuit
Overvoltage Protection Circuit
Soft on / off Circuit
CLEAR ACRYLIC Mounting Brackets & Hardware
Elmer the wricer hunter..."Shhh be vewy vewy quiet...I'm huntin wrice"
Kill da wriiiicer...Kill da Wricerrrrr..kill daaa wriccceeerr!!!
