6.5 component door panel fit question - Audio & Electronics Forum
Friday, October 05, 2007 6:05 PM
ok I got some candance 6.5 components, used some 3/4 mdf to make adapters.
2 issues, speakers back barely clear the window. (I had to take the rubber cover off the magnet) but at the very bottom there might still be a bit of touching.
the 2nd issue, is the door panel doesnt fit perfect any more. do I have to trim the crap off the adaptor to be just barely bigger then the speaker?
or is that just the way it is?
Re: 6.5 component door panel fit question
Sunday, October 07, 2007 4:57 AM
I put 6 3/4 in my doors, the door panel will not fit tight without modification (sanding a little, or whole removal and addition of speaker cover). As for Depth, how deep are they? you have barely 2 inches maybe 2 1/4 or less inches behind the metal, not a lot of room for these bigger speakers.
Sunday, October 07, 2007 5:52 AM
I have Morel 6.5" speakers in my door...
You do know that stereo shops sell adapters so you dont need to make your own right??
I have heard some thicker speakers like Type R's won't fit in all car doors though without modification....
Sunday, October 07, 2007 7:54 AM
id much prefer mdg over the cheap plastic adapters. youlle most likely have to trim that ring as much as u can and see wehre your hitting, also you can modify the frame rail and push it back a 1/4" or so without much problems.
Sunday, October 07, 2007 11:10 AM
MDF is only $3 at Home Depot. Those adaptors are 20 or more, and I have mine in 10 minutes (as thats as long as it takes to cut them out).
Monday, October 08, 2007 8:09 PM
use MDF, i got infinities and they fit perfect. The magnet on the speakers is small and the door panel fits no problem
