Any way to make them faster or swap them out with motors from another car that move faster. My passenger side takes literally a minute to fully close and will only close when I'm closing it alone. Closing the driver window and the moon roof at the same time will make the passenger window stop.
heavier gauge wire also helps
The Passenger's window has been slow since the day I bought the car... never really complained about it. When I installed tint on it, it was even slower. I removed the tint though cuz I got busted by the cops when I had your car with me when I was living in chicago.
Guess Who's back!!!
window pad tension adjusters?
Replacing the motors with stock replacements works wonders. If your passenger side window is slower than your drivers side... the driver side motor has probably been replaced.. its usually the other way around since the driver side gets used more.
btw... you car is running when you roll them up right?..... it makes a huge difference. My power windows put more of a load on the electrical system than my almost 2000watt stereo.
Just replace the motor and it should work fine.
