I have a 04 cavi, and want to install my system. I have everything done i just dont know where to put the starter. I dont want to put it through the ignition and was wondering if there was a spot for it in the fuse box. Also, i have a stock deck. Thanks
the starter? are you talking remote turn on lead?
ya, thts it, i couldnt remember the actual name. so do u think u can help?
you can use an add a fuse and tap into the wipers.
also if your using a stock deck how are you connecting the amps to the radio?
Umm...wut would u do if u have power windows?
and mclonedogmcwad , can u be a bit more specific about the add a fuse and the tapping in through the wires
Go to an autoparts store and ask for a mini-atc fuse tap should look something like this
where in the fuse box should i install the mini atc fuse tap.
Also, are there any other ways i can install the remote lead.
Thanks.
