I ran a search but didn't find anything. Where is a good place to get a flush mount mounting kit? company or part #? and another ? . I'm a bit confused, I understand that you can get a wiring kit and loose your chimes but I remember reading somewhere something about if you do it that way your player will not hold memory? Thanks for the help!!
it'll hold memory, you just have to run you're own memory wire from the deck to a constant 12V source in the fuse box. its really easy. the mounting kit, you can get those anywhere. i think i got mine at walmart.
GO PATS!!!
Yea I seen them there! I've only seen the kits that sets the player out of the dash.
Metra 99-2003 is the dash kit. If you use the jury-rig harness you have to run ignition to the fuse box or ignition harness.
-Chris
