Edit: Does anyone know what the ports in this enclosure are tuned to? i want to build a box like this but i just dont want to go and spend 400$ for just the enclosure..
Thanks
www.driftnamiperformance.com
I didnt bother e-mailing them because i figured i'd get a quicker response from here than waiting on an e-mail..
we dont work for the company.... you would have better luck emailing them than hoping one of us know.
KevinP (Stabby McShankyou) wrote:not funny... i just can't find that funny... not with 2 copies of the Candyland board game on your shelf.
Well First things first. What subs are you going to put in the box. Get the specs off of the speaker and see what the max air space it calls for and what is the best Hz it recommends for the best tuning. Then find out what the sub is better of in ( sealed or ported. Depending if you like SQ or SPL.
These are the specs for the 8Ohm 12" P1
Rec. Sealed Enclosure 1.02 cu. ft. (28.88 liters)
Range: 0.70 cu. ft. - 1.80 cu. ft.
Range: (19.82 liters - 50.97 liters)
Rec. Vented Enclosure 1.79 cu. ft. (50.69 liters)
Tuning Frequency (vented) 36 Hz
Port: (1) 3" diam. x 6" long
Port: (1) 7.62 cm x 15.24 cm
Note: the box shown in the link is dual chambered @ 2.51f^3 per chamber. and the port is tuned @ most likely 36 hertz.
I may be wrong but if its a RF Sub thats in a RF box. So there going to tune the ports to the correct specs.
