Which harness wire to tap for stereo dimmer? - Audio & Electronics Forum
Wednesday, June 13, 2007 7:29 PM
Which stock harness wire can I safely tap into for the dimmer signal on my aftermarket stereo? It's a PITA to change the color settings all the time, and the daytime setting is distractingly bright at night posing a safety hazard. Thanks.
Re: Which harness wire to tap for stereo dimmer?
Sunday, June 17, 2007 12:38 PM
on my 97 sunfire it was an orange wire. I believe the12volt.com has a wiring schematic for sunfires and cavaliers.. Check there.
-Justin
Sunday, June 17, 2007 12:42 PM
Scratch that... Dimmer on the 97 sunfire is brown from the harness. Here is the link for a 98 sunfire which im sure is the same wiring as your Cav.. http://www.the12volt.com/installbay/stereodetail/1895.html
hope this helps,
Justin
