how do i wire up - Audio & Electronics Forum
how do i wire up
Sunday, May 06, 2007 10:23 PM
hey how can i wire up a 4 channel amp and a 1 channel amp??? the 4 channel its going to my doors and rear speakers and the 1 channel its going to my sub but how do i wire both amps at the same time? and do i need to send each sire from the 4 channel to every door speaker? or can i just connect them directly to the cd-player??????????
Re: how do i wire up
Monday, May 07, 2007 9:06 AM
if your deck has dual outputs, then you run RCA cables to each amp, if not then an RCA splitter should work fine to get the signal to both amps. as for speaker output, your speakers will need to get signal from the 4ch amp and not the deck, otherwise the amp is useless. get yourself a set of distribution blocks for the power and ground connections as well.
Monday, May 07, 2007 12:08 PM
alright thanks a lot i have trying to do this but u know couldn't find ppl that knows how to... but hey thanks again
Monday, May 07, 2007 3:31 PM
Honestly this is very easy and logical. You just need to think about it. Searching is your friend. Most companies that sell amps have wiring diagrams. Not to mention the vast amount of knowledge google can share.
Whats up people?
