pic request for spots for inline fuse on eco and how to run 0/1 - Audio & Electronics Forum
Saturday, April 21, 2007 10:31 PM
Hey,
I installed some wire this weekend and I had a little bit of a hard time.
1. If you have an eco, where did you mount your inline fuse holder?? I have mine sitting on my intake but that isn't gonna cut it.
2. If you've ran 0/1, how did you get it to the trunk??? Mine sits just basically all out and ran from the front to the back which isn't gonna cut it either. I know it needs to go under the carpet but I can't think of a way to do it without getting a huge rise in the carpet.
Any help is appreciated.
Thanks
-Seth
Re: pic request for spots for inline fuse on eco and how to run 0/1
Sunday, April 22, 2007 9:24 AM
it will fit in the door sill under the carpet just fine.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Sunday, April 22, 2007 11:37 AM
K, I tried there but it was bein a bitch. Maybe when I take a seat out it'll be a bunch easier.
Any idea on the fuse???
-Seth
Sunday, April 22, 2007 12:35 PM
i mounted my fuse on the frame by the battery on mine when i ran the 1/0. then i now have a audison fused battery terminal and definatly cleans it up..as for the runnin just runs down the door sill nicely..i used some rubber isolated holders that screw down to hold it..hope that helps..phil
Sunday, April 22, 2007 2:24 PM
Thanks
That audison piece looks pretty cool.
I think it might be beneficial to get an optima, not only for the better battery but so I can get top posts too.
-Seth
Sunday, April 22, 2007 6:49 PM
run it on the inside of the orange wire loom that is already there, it would be easier if you took the seat out and pulled the carpet back
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Monday, April 23, 2007 1:51 PM
i always pull the seats when running wire, makes it 10x easier, i usually run mine right beside the center console and floor on the drivers side.
Monday, April 23, 2007 6:10 PM
I just did my 03 yesterday, I pulled out the seats and ran the wire under them. I used 2awg in that one.
As far as mounting the fuse holder:
Here is where I mounted it on my 02. I ran 0awg Power and Ground in that car to the rear battery.
I took out the Passenger seat to run my 3 sets or rca cables and remote wire.
It is hard enough tryin to get our plastic panels back on without any wires under them, much less a piece of 0guage. So like JAson stated it is EASIER that way. Plus only 4 13mm nuts hold our seats in anyway.
Monday, April 23, 2007 8:49 PM
Thanks you guys.
I think when I go to put everything else in in about a month, I'll rerun everything.
-Seth
Monday, April 30, 2007 8:28 PM
I ran mine underneath the car. Loom it up and bring it in inside the trunk, works nice that way.
Under Construction
