alternator to battery positive wire on the BIG 3 Question - Audio & Electronics Forum
Monday, April 30, 2007 11:16 AM
if my stock alternator to battery positive wire runs threw the stock fuse panel, does that mean I do not need to add a inline fuse when I do the BIG 3?
Re: alternator to battery positive wire on the BIG 3 Question
Monday, April 30, 2007 11:20 AM
no you still do. unless you want to run the risk of catching your car on fire.
Monday, April 30, 2007 2:07 PM
run an inline fuse in the wiring, i used a 150AMP ANL fuse (4.ga wire) and its been working fine.
Monday, April 30, 2007 2:12 PM
I havent ran a fuse on my big 3 alt wire ever.
As I secure the wire out of the way and prevent it from becoming damaged in any way possible.
The fuse is to protect the wire from becoming damaged and creating a short and starting a fire, but if you keep it away from the header, and or other moving parts, you should be safe.
Alex
Elemental Designs
Performance.Mobile.Audio.
alexl@edesignaudio.com
Warehouse Manager
Monday, April 30, 2007 2:18 PM
Im going to fuse it to be safe, also one more question, if my altornator power wire goes to my starter or to my fuse box before it goes to the positive on the battery do i have to replace those wires too? or do i just go from the altornator to the battery and not worry about the outher stuff? or should i go from the altornator and to all that outher stuff then to the positive terminal on the battery with the new wires? which way is best?
Monday, April 30, 2007 2:43 PM
Alex Lindeman wrote:I havent ran a fuse on my big 3 alt wire ever.
Alex
we all try our best to prevent our amp wires from being in harms way also, doesn't mean you shouldn't fuse it. Accidents do happen.
Any hot wire coming off the battery, should be fused.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Monday, April 30, 2007 4:50 PM
Alex
I tied mine up directly to the "STOCK WIRE" coming from the alternator and DID NOT USE A FUSE. The factory wire doesn't have one either. If you get hit bad enough in a wreck and you blow the "NEW FUSE" what about the stock wire that everyone leaves there?
Monday, April 30, 2007 7:17 PM
Alex
your right, the factory wire doesn't have a conventional fuse in it. There is a small section that has a smaller gauge wire, that will break if a short were to happen. I think they call that a fusible link?
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Tuesday, May 01, 2007 8:33 AM
wysiwyg wrote:There is a small section that has a smaller gauge wire, that will break if a short were to happen. I think they call that a fusible link?
yep, absolutly correct. i was wondering about putting a fuse in my alt to batt. big 3 wire as well, looks like its going to happen now.
Tuesday, May 01, 2007 10:51 AM
Is doing the BIG 3 the same as Hypergrounding or is Hypergrounding something else?
Tuesday, May 01, 2007 2:13 PM
its basically the same thing, just with the hypergrounding, your grounding more items.
