GAUGE CLUSTER LIGHTING - Audio & Electronics Forum
Monday, April 23, 2007 7:39 PM
just wondering how to access the the light bulbs in the gauge cluster? im about to remove my dash for weight reduction, and want to try to avoid having the airbag light on. any help would be great
thanks
The one, the only, ME.
Re: GAUGE CLUSTER LIGHTING
Tuesday, April 24, 2007 12:07 PM
forgot to mention that its on an 03+ sunfire.
Tuesday, April 24, 2007 5:17 PM
You have to remove the dashpad bezel that goes around gauges and cd player/hvac then the 2 bolts on the cluster its self. There are tabs along the outside of the cluster that should take off the front plexi and rear cover. You need to remove the needles(not sure how), Then there are 6 bulbs in there plus the mileage readout
Sunday, April 29, 2007 8:25 AM
be careful when removing the needles though, I've read that you can pull the metal pole on the needles out of the little motor that moves them and then you're screwed. If you're doing it by hand, then it's a coin toss whether you break it or not. Get a special tool for the job, I'm sure there's one out there for that.
Sunday, May 13, 2007 2:23 AM
Do it the cheap way, put a small piece of black electrical tape over the airbag light. Its a ton safer and easier than trying to mess with de-soldering the surface mounted LED that illuminates it.
Sunday, May 13, 2007 11:32 AM
just cover it , its just an led, and if the gauge has a malfunction with the leds, say hello to the service light haha, trust me, just pull the needles off, (VERY SLOWLY by the black circles) then peel back the overlay
http://www.cardomain.com/ride/2267189
