most likely you will jsut have to cut out the plastic cage and sand down the bezel, it should be fine.
well the Kenwood 6.95" Double Din headunits fit in the FACTORY OPENING of the 00+ J Bodies. I am going to go out on a limb here and guess the Clarion is the same way.
So as long as you have a 00+ Dash Bezel in your gire (not sure what year you have) you'll be good. The Metra 99-2003 Dash Kit has brackets in it for the double din to be ISO mounted.
