I just bought another 4 channel amp so i could run my front and rear speakers. I've read the manual but it only tells me about subwoofers, how do i go about running them? do i go from head unit to amp then amp to speakers? or is there a better way i'm supposed to do it.
Thanks,
2003 White Cavalier LS Sport Coupe
Ummm...Take your front and rear channel RCA's from the head unit.
Plug them into the amp
Run speaker wire from amp to speakers...1 channel/1 speaker...
Really? its that easy? lol, so i just don't use the speaker wire that goes from the head unit to the speaker, just cut it off and run it from amp to speaker?
Yes. Wire the speakers directly to the amp's channels. Why would it be any different than hooking up a subwoofer?
LOL
well if they would use the rca's then what are the wires coming from the high pass side?
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
Stitch wrote:Really? its that easy? lol, so i just don't use the speaker wire that goes from the head unit to the speaker, just cut it off and run it from amp to speaker?
No..put bombtails on the end of those and move away from them very slowly...They are dead now, you must accept that.
I have no idea what your last question is asking...
Forget everything on the back of the headunit for now BESIDES the Front and Rear RCA outputs....
Run some cables from those to the Amp...Plug speakers into amp using speaker wire...Enjoy the much much better sound..
What kind of amp?
An Orion HP4600
Thanks everyone, lol/
Patrick Myers wrote:well if they would use the rca's then what are the wires coming from the high pass side?
Uhmmm, speaker level inputs perhaps?
LOL
you need a 3 chanel head unit. ie sub, front, back rca outputs on the back. and wire up like the sub only select on the amp 'full" instead of 'sub' (should have a switch)
yeah, i've got an Alpine X890 its got all those
