I have the Jensen Indash 7in dvd screen and an alpine 10" flipdown in my cavi.
I dont like the unit as a deck, and I am wanting to run my pioneer deck at the same time. Is this possible?
I want to watch a dvd but listen to what I want, but when I want to hear the dvd I can as well.
-Thanks for the help.
Im almost postive that your jensen has audio/video out. And if you pioneer has an AUX mode or a input mode you can just run a set of rcas to your pioneer from your jensen, and put you pioneer on AUX/Input mode. Dont really know what models your working with though.
its a DEH-P6600 pioneer deck and a the non touch screen jensen
yep you can do it you will need the cdrb10 can be found here
INPUT ADAPTER . Then a rca cable to run from the hideaway unit of the dvd reciver. to you new input adapter. I would say a 9 footer will do.
On your jensen hideaway unit you just need to connect the rca cable to one of the outputs.
The link that I gave you for the adapter, I am almost sertain you can find it cheaper somewhere elese.
my jensen has no hide away unit?
It does have aux input tho, however im not sure if the sound will come out thru the pioneer deck.
Ok I found the adapter on ebay thanks!
So Ill wire up the pioneer cd player to everything....then just wire up the dvd screen with no speaker wire hooked up and just run it thru the adapters RCAs?
sorry if this is noob @!#$
yessir, i ran out of post
so had to make a backup
okay one more question.
Can my pioneer deck mount in my console facing up and still play fine?
I cant get my HVAC panel out so I was just gonna console it.
Steven cowen wrote:yessir, i ran out of post
thats against rules dude, go preme
ok thanks for the help deck and tv is in.
LASTLY
I have 2 amps, one for interior speakers and a sub amp.
I hooked the speaker amp up with the RCA on back of the deck, and it adjusts them like its the sub woofer? Am I missing something here?
I have the sub RCAs going to the sub amp.
