I got new light bulbs for my GFs cav and went to install them and only one lights up. I tested it with a test light and it is getting power. I know the bulb is good because when it goes to the other side it works fine. Whats wrong, could it be a ground? How could one work not the other when I know it is getting power, too many problems with these cars.
Chris
2.3-2.4 HO ADAPTER FLANGES 65$ shipped, Check GP Forum!
There is always 12+ volts going to the bulbs. I believe the ground is what is switched. So check to see if the other wire is providing a ground when the light switch is on. If not, that's your problem. I had to trace my wires back on my car, and turned out a ground was corroded. Otherwise look at the harness and see if it is melted or corroded.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Luke Heier wrote:There is always 12+ volts going to the bulbs. I believe the ground is what is switched. So check to see if the other wire is providing a ground when the light switch is on. If not, that's your problem. I had to trace my wires back on my car, and turned out a ground was corroded. Otherwise look at the harness and see if it is melted or corroded.
is it 9007 bulbs? 95-99 00-02?
^^^Ahhh, good point.. I'm assuming he has 95-99
1997 GMC Sierra
2005 Honda TRX450R
