2003 Cavalier Aftermarket deck problems - Audio & Electronics Forum
Monday, March 12, 2007 1:57 PM
hey,
i recently purchased a 2003 cavalier and am wanting to put my infinity sound system into it,.. i have an aftermarket JVC deck and want to put it in.. i looked at the sticky notes and am aware of the chimes and all that stuff.. my problem is that i bought a harness from canadian tire that will work for chev models 2000 and up.. (works for 02-04 blazer, 01-02 express van, 00-04 tracker etc) and it fits into the harness perfectly ( i don't care about my chimes and don't want to use the expensive harness with the relocation kit)..after hookin up all the wires.. the deck would not kick on.. so i took out the wires and made sure i had power and i had power.. i took apart the ground wire to check it also.. and i put the two together and the deck lit up for only one second and then it shut back down.. i unhooked it and hooked it up again and put the groun together again and it lit up for a second and shut off soon after.. i'm thinkin that there is a safety of some sort on the harness or soemthing.. any help would be greatly appreciated .. thanks
Re: 2003 Cavalier Aftermarket deck problems
Monday, March 12, 2007 2:04 PM
you have to run the red power wire to a power sorce...such as the fuse box
Monday, March 12, 2007 2:08 PM
so i can run it to the ignition or headlights in the fusebox ?
Monday, March 12, 2007 2:09 PM
go for the wiper fuse
Monday, March 12, 2007 2:10 PM
alright,.. thanks man
Monday, March 12, 2007 2:11 PM
oh, on another note.. the ground wire.. do i just connect it to the black wire from the harness or connect it to the frame?
Monday, March 12, 2007 2:12 PM
You can do either but it will probally be easier to do the harness. but either one works.
Monday, March 12, 2007 2:16 PM
thanks buddy
