2005 Sunfire Fog Lights - Audio & Electronics Forum
Monday, March 12, 2007 1:20 PM
I have a 05 Sunfire and put in HID lights..In doing this I had to bypass the DRL...So what I would like to do is use the factory switch in the car to control the fog lights..But I don't want to have to turn the parking lights on ever time..So I was hoping to just hook a ignition lead in place of the factory trip wire to the fog light switch..What I have found is blue is 12 volts out to fog lights.. middle wire is black constant ground.And the last orange is only 7 volts when the parking lights are turned on..then when you turn the switch on it goes to ground for a second then back to 7 volts..So I am wondering do I have to use a resistor to bring 12 volts down to 7 volts or is there another way of doing this any help would be great thanks..Jason
Re: 2005 Sunfire Fog Lights
Tuesday, March 13, 2007 12:05 AM
So no one out there has tried to do this...
Thursday, March 15, 2007 1:03 PM
Floating ground... you need to replace the switch you have (momentary) with a switch from a 95-99 Sunfire (actual switch on/off) and wire directly to the fog lamps (or a relay).
The current switch is a pushbutton, pushing it "asks" the BCM to turn on and off the lights... the BCM controls ground to the foglamp relay.
I tried it... had to swap the switch for a real one, not a momentary button.
Friday, March 16, 2007 8:17 AM
ive been wanting to do this too, except either have the high beams, or fog lights to come on just like the low beams did with DRL, any possibility?
http://www.cardomain.com/ride/2267189
