Top/Bottom - 25.5x35.5
back - 13.5x35.5
front - 13.5x15.25
front - 13.5x15.25
sides - 13.5x24
port - 13.5x16.25
port - 13.5x16.25
Hopefully it fits!! lol
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
what program did you use to create that.
That's tuned way too high bro, bump it down a little to at least 35-36. Where you have it now won't sound good for music.
i had a box tuned at 38 before and it wasnt that bad, im gonna try it ou and if i dont like it i can always build a new 1...its only $40cdn in material so no biggy really
well the box building FINALLY started, didnt get much done 2night as the little guy was sleeping but with the way the weather is looking for friday i dont think i will be wokring
the peices are jsut sitting here so its not alinged 100%
i got farther then this dont worry lol i jsut hope it fits in my car lol
If i give you the dimensions of my box can you get me a 3d drawing with all the measurements like that?
Heres my specs
To get a box that would work, I would go with 14 tall, 34 wide, 30" deep. Put the subs on top firing up (that way you can get all 4 on the 34x30 side of the box, put the port firing out of the back, 12.5" tall (full internal height of the box), 6" wide 20" long
its for 4 12's
TIA
hey, i didnt make the drawing so i cant do it for you man
What subs are you running with that box? Sounds almost identical to my box, except mine's a little bigger than that.
Audiobahn AW1206Ts, i know audiobahn sucks blah blah blah lol they where sitting around for 3-4 years and my sub blew in my beater so i thought i would throw them in
141.1db with a termlab now i jsut need to double my power and work on my electical system, the volts where dropping down to 11.5-12 on hard hits and after my run i remembered i had my line driver turned down alittle bit lol
ill have some updated pics tommorow as it was to dark by the time i got my box in the car
i never got a chance to put the corner pieces on the inside of the box as my table saw didnt want to cut angles for some reason
im gonna get some cut then remove my subs and glue/screw them in to see if it helps at all
and i dont have a spot for my rear speakers anymore lol
try facing them towards the trunk, you'll gain some db's.
u think so? a buddy had a 15" XXX with a huge box like mine that blocked most of the air from going into the cab and it was louder facing the cab....when it gets warmer i might rip it out and try it the other way around
