Well i started a thread a couple weeks back saying i was considering getting a set of ED's eu-700 so i could have a trunk. But i decided i dont need a trunk anyways
. So i ordered 2 13kv.3 D2 from elemental designs along with a nine.1.
Then i got a idea. I should do 4 13kv.3's so i could use the amps full power, at 1 ohm. So now Im ordering 2 more. I started to build the box yesterday. Its 6.4 cubes tuned to 34 hz
This was the first box i have ever built. I still have to cut the holes for the subs.
So what kind of Numbers should I expect from this. Ed rates their amps at 12.5 volts, and at 12.5 volts it puts out 1200rms at 1 ohm. But i heard the average is acutally around 1400 rms with higher voltage.
Anyways heres some random pics:
Some of the pics were before I cleaned up the box. All 4 subs will be firing up with a port exiting out the rear drivers side of the box.
Comments welcome
130-180dbeees
that box looks kinda small for 6.4 cubes is that before or after sub and port displacment(inside or outside of the box)?
anyways with what ya got you should be around 140-142 on the termlab.
have fun fitting that in the trunk
Yea it fits after I cut part of the braces out, the one that are in the middle of the the back seat and the trunk. And the 6.4 is before port after drivers. The port wall moved a little over night that why theres so much glue there. Im wating for the battery on my jig saw to charge so i can finish the sub cutouts.
