subwoofer cutout at low RPM - Audio & Electronics Forum
Friday, February 16, 2007 9:29 AM
i have a 1997 sunfire gt and when i have my subs turned up at a low RPM they have a tendincey to cut out...i just replaced the alternator like 3 weeks ago...and battery...does anyone else have this problem or had?..and if so what did u do to fix it?...thanks for you time any and all comments will be greatly apprciated!
Re: subwoofer cutout at low RPM
Friday, February 16, 2007 1:43 PM
Your subwoofers, or your amplifier is cutting off??
Sounds to me like a voltage problem. Use a dmm to test the votlage at the amp during play.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Sunday, February 18, 2007 5:18 PM
check and see if your amp is going into protection. some amps have a thermal and other types of protection which is usually indicated by an LED or the power LED turning a different colour than normal.
1997 RedR - ZedR
Sunday, February 18, 2007 8:00 PM
Check your ground.
Monday, February 19, 2007 12:37 PM
mine use to do the same thing and i couldnt figure it out. i had good voltage to it. i thought it was the sub and amp combo but then it got stolen before i could figure it out. haha
