the five pin flasher works on the 98 cav for running leds WITHOUT loads
Grote p/n 44090
you do know the resistor is to limit voltage right? Im not sure how something set up for 12 volts (flasher) isnt cooking 1 volt led.s
If you knew what I was talking about you wouldn 't have made that post
Those are the load resistors that make the flasher work correctly not the current limiting/ voltage drop resistors
I have an electronic engineering degree
Winner
I'll back that.
Thanks for the P/N, there's a post buried in this section that has the 5-pin discussion
Load resistors are easy to wire... one wire goes to the turn sig positive, the other to the turn sig ground (in parallel with the bulb).
I can post a diagram if you need it when I get home from work.
The flasher is a direct replacement to the stock one.
Very bad paint wiring diagram (ignore the blue line, that's the park light positive)
i hate to sound new... but how many of the above mentioned flashers do our cars use?
Edited 1 time(s). Last edited Monday, February 12, 2007 1:07 PM
car audio noob since 1984.
i just ordered my grote flasher. only place i could find one was midway auto supply online.
