Alright I have Searched and searched and i think i narrowed down the problem....obviously my horn don't work. My question is the white plastic piece on the little spring thing (as pictured) is broke in half. Is the white plastic shaft significant at all? the red wire running from it looks crushed too? are either or both of these the reason the horn is not working? TIA
Yes i checked the fuse...and in addition to that when i press the horn i don't hear a click sound
http://www.cardomain.com/id/blinkhero
"In JDM Land the coke truck would have more amber"
I actually just got my horn working again. Leave the ground wire as is...What you are going to want to do is on the steering column there is the yellow wire for the airbag on the right side. On the top left is a little hole, put the red wire in the hole and some how secure it in there and your horn should work. The hole you are looking for is the one that will allow you to push the red wire in the deepest.
That little plastic thing around the positive wire on mine was smashed so i just taped it back together then secured it in the hole and my horn now works fine.
Yeah, i put it in the hole,it is possible that it did pop out...how did you secure it? tape? another wire? TIA
