Sunfire Tachometer Signal Source - Audio & Electronics Forum
Saturday, February 03, 2007 8:49 PM
Where does the Tach Signal come from on a '96 Sunfire 2.2 ? The Crank Sensor, the Ignition Module, or both ? I know the PCM sends it through the UART/Serial Data Line to the Instrument Panel Cluster. But the PCM gets it from somewhere.
Thanks...
Re: Sunfire Tachometer Signal Source
Saturday, February 03, 2007 8:52 PM
purple wire on the coil packs
Sunday, February 04, 2007 12:06 AM
PONTIAC, SUNFIRE, 1996, Tachometer
The engine harness is found next to the battery, below the radiator hose, just above the transaxle. Use white or orange on the 2.2L motor, and purple/white on the 2.4L motor.
Sunday, February 04, 2007 6:28 AM
It's a 2.2... Use the White or the Orange ?
Monday, February 05, 2007 7:32 PM
Are you saying the Ignition Module sends the signal to the I/P Cluster ? If so, how does the Ignition Module know when to fire ? I'm "out of the loop" on this one. I need to pull a signal from a 3800SC and send it to the I/P Cluster on my Sunfire. I know where the Tach wire is on the 3800SC, and I was hoping I could just use the Crank Sensor on the 3800SC to send a Signal to the Sufire I/P Cluster. Are you really lost now ???
Monday, April 02, 2007 5:53 PM
Do you know if this information would hold true for a '95 Cavalier with the 2.2L engine? about which wire to use to get the tach signal?
