back seat box... - Audio & Electronics Forum
back seat box...
Thursday, January 11, 2007 10:35 AM
Well i decided i dont want my back seat anymore so i want to make a nice ported fiberglass box for my sunfire..now te question lies in will i lose the loudness from it? like the back and bottom will be made out of 3/4 mdf so it will plug off the trunk but will that be enough and if not what do i have to do? phil
Re: back seat box...
Thursday, January 11, 2007 5:22 PM
not sure how to answer your question but I like your idea, there is an option, RKsport makes a box to hold four subs and a couplle mid range speakers also, it takes the place of your rear seat, made out of fiberlgass or carbon fiber, I thought I might just run that buy you, but the price is high, may be cheaper to go and build your own enclosure.
my buddy had a speaker wall in the back of his cavalier once, he had 8 12" subs and it was louder than heck! lol
Thursday, January 11, 2007 5:27 PM
I have a big bastard box in my trunk, fits 4 12's, ported, wangs. I used my back seat area for my amp rack.
Thursday, January 11, 2007 5:46 PM
i got me a backseat box. dont need no stinking rearview
Thursday, January 11, 2007 6:23 PM
Lanman31337 - Cavfire wrote:I have a big bastard box in my trunk, fits 4 12's, ported, wangs. I used my back seat area for my amp rack.
You and ur "wangin" lmao...Cracks me up every time
And Philly D if you seal the trunk off from the cab with the box you will likely gain volume.
LOL
Thursday, January 11, 2007 7:18 PM
i was thinkin about doin the same thing but im just goin to do a wall., you can fiberglass the box into the back seat to seal everything off. by doin that it will sound better to the ear and also get alot louder then havin the sub's face back.
Thursday, January 11, 2007 11:54 PM
this is how i sealed off my trunk when i was working on mine. 3/4" MDF,"L" brackets and some skrews. then i put sound deadener over it to cover up the small gaps around the edges.
Friday, January 12, 2007 8:03 AM
your problems arise with cancellation as long as the subs are on the back wall so to speak you should be fine. so seal up the trunk opening as said above and you should be fine. also dont forget to seal up the rear deck and the opening behind your side panels below the back side windows.
Friday, January 12, 2007 9:34 AM
chad spender wrote:not sure how to answer your question but I like your idea, there is an option, RKsport makes a box to hold four subs and a couplle mid range speakers also, it takes the place of your rear seat, made out of fiberlgass or carbon fiber, I thought I might just run that buy you, but the price is high, may be cheaper to go and build your own enclosure.
actually its only a shell. you still have to build the box behind it in order for it to work
Friday, January 12, 2007 10:05 AM
so im thinking do what du tang did seal off the 6/9 holes or could i run some? and then use expansion foam for the area on the sides..i know there is a bit of area by the hinges but yah..then build the box from there..im not making a wall but itd be nice to have a bit of a trunk for amps and such and display the pretty sub ect lol..anyone make a ported fiberglass box? hard? phil
Friday, January 12, 2007 10:08 AM
You'd have to mostly make it out of mdf, and maybe use aeroports and glass them in.
Saturday, January 13, 2007 3:10 PM
I was thinking of making a back plate...small sides..flat bottom then makeing a slot port on the bottom facing forward and then mount the sub inverted about the port with a mdf ring and make afew braces for it ..phil
