Ok so i am going through the build of my next system i would like to build up. it includes 3 Alpine PDX 1.1000 that would total 240A at 80A per amp. then theres a PDX 4.150 for the components that is rated at a total 60A for a total of 300A for the main fuse. is it safe to run an ANL that is rated at 300A on a single 1/0ga or should i get a 300 and then also run seperate fuses after the distribution block? im not a complete novice but have never really went into alot of power till now when i am finally free to do as i please when it comes to my vehicle. oh btw im gonna run 3 Infinity Kappa 124.7W 12" subwoofers with the 3 alpine units. any info would be greatly appreciated. TIA
you need to fuse your main power wire...and if you split it, you must fuse each new wire accordingly.
so run a 300amp fuse on your 1/0....and if you split it to 4awg, run 125 amp fuses on your 4awg wires.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
alright cool. also if i relocate my battery what fuse size should i run on that line? i dont want my main fuses going wacko but i am going to be cleaning my engine bay of most wires and such here shortly. havent ever done it but it should be a good idea to fuse it seeing as how far away the fuse box will be.... even after relocating that i will be keeping it under the dashboard so.....
