So yea, I have cut and choped about 300ft of stock harness out of my car and after I tested everything im still using and it ALL worked fine, well after taking fuses out for eveything i dont use any more(OEM headlight fuses, OEM amp, Wiper, A/C, ect) My OBD-II seemed to lose power, well I replaced all the fuses and it didnt fix my problem.
where is my power loss?
i thought it only gets power with the key in the run position
Machzel08 wrote:i thought it only gets power with the key in the run position
I second that. I always have to turn my car to run when I take it to Checker to get it checked.
-Seth
You're losing power to ignition somewhere.
Car on(and runnig even)
and the OBD was working after i cut out all the unused harness so i know its not from that.
