Hi all i can't seem to find a diagram for a (-) trunk pop
also do i have to go right to the trunk lock or can i get the wire in kickpanel like with keyless cars.
anyhelp would be great
drivers kick panel
black wire white stripe
postivive trigger
use relay to reverse
there are 4 black wires with white stripes in the 3 harnesses down there at the bcm. it should be the one in the purple harness. the info that bulldogsecurity.com give is wrong on the trunk pop at least for my year. alos mine needed postive not negative. if you hit the wire before the switch its neg. if you hit it after the switch its pos. that is if you already have the switch.
(2002 cavalier coupe AT)
pull up the door sill peice and follow that chunk of wires.....thats what i did to fint he wire
