Just Installed Power Windows - Audio & Electronics Forum
Friday, November 17, 2006 11:03 AM
Ok so i want the the crap yard and got the actuators (entire assembly with motors) for both sides. I installed them, everything checks out fine. now im sitting here with the wiring problem on my hand. I've got my windows half way down and no way to roll them up =/. I have the switch for the center console and the harness for it to. But i need to know how to wire it. Are there any relays involved? or do they wire directly to the switch and fuse pannel. (That would be sweet, I hate relays).
Re: Just Installed Power Windows
Friday, November 17, 2006 11:24 AM
im assuming relays first unless there are relays built into the actuators.
Injection is nice but id rather be BLOWN!
Thursday, January 11, 2007 10:04 AM
ZERO relays!
Every thing you need is built into the switch, you run the dark brown and dark blue to the diver side, the light brown and light blue to the passenger side, black ground to metal on the car, grey is the ilumination wire, and the last bown wire is for the power witch you run to the fuse box and splice into the brown wire leaving the back of the fuse marked power windows (even if you have crank windows you will still have this fuse, its the lowest fuse, and its a silver metal fuse)
I did what?
Shut the @!#$ up no I didn't!
I did?
Friday, January 12, 2007 7:23 PM
not tryin to spam this link but i just wired up my windows that i got and i wanted to test them before i installed them and they go up and down figured out all of the wireing thanx to 99whitefire and for some reason the express down dosent work where you push down on the driverside button and the window keeps going all by its self and i was looking on that diagram and it mentions a express down module and i was wondering if i left something behind at the junk yard or i messed up on something any info would be awsome.
