Interior Wiring Harness - Audio & Electronics Forum
Tuesday, November 14, 2006 5:23 AM
Is it possible to switch a 96 sunfire interior wiring harness with a 2004 cavalier interior wiring harness. The reason I am doing this is because I want power locks and windows and I couldnt find a sunfire in the junk yard that had both.
Re: Interior Wiring Harness
Tuesday, November 14, 2006 5:01 PM
Dude way too much work just for power windows and locks.
You can just by kits and do it yourself...hell there is group purchase on the locks.....http://www.j-body.org/forums/read.php?f=50&i=26893&t=26893
Wednesday, November 15, 2006 2:50 PM
The interior harness has lots on it... including all the rear lights and so on... you'll probably want to stick with something a little closer in year, as well as being the same type of car... since there are lights in different places on a Cavalier, compared to a Sunfire. eg. license plate, bumper lights, etc...
There are differences between the 95-99 harnesses and 00-05 harness that will make swapping a pain... notably the changes between convenience centre (95-99) and BCM (00-05). The trunk light is wired slightly differently and is a pain to switch. 00+ has a diode hidden in the tape around the harness. It's right by the big black connector (C102 I believe).
Thursday, November 16, 2006 6:41 AM
I noticed that the pins in the main connector are removable. If I were to undo the bundle of wires in the 01 Cav harness and pull out the wires I need, will I then be able to add them to my existing harness?
Thursday, November 16, 2006 11:24 AM
Yup... sure can! I've done it a number of times. In fact, the harness in my 2000 'vert is made from a 01 Sunfire coupe w/ 99 Cavalier convertible spliced into it.
...j
