e-brake override for in dash monitors - Audio & Electronics Forum
Monday, October 30, 2006 8:54 PM
does anyone know how to hook up the wire for the video to where you dont need the e brake involved at all,in other words how to hook up a toggle swtich.
http://memimage.cardomain.net/member_images/12/web/2352000-2352999/2352565_22.jpg
Re: e-brake override for in dash monitors
Monday, October 30, 2006 9:02 PM
Make and model of the unit is going to be needed. I know some work by simply grounding the wire.
Sold 6/30/06.
Tuesday, October 31, 2006 3:01 PM
If you search, i posted how to do it three different ways...
The simple ground
With a switch
and with a relay
There are more complicated systems, and they need a hacked firmware upgrade to overide, but they are high end and/or factory models
edit
http://www.j-body.org/forums/read.php?f=4&i=127946&t=127736#127946
Read my post, about 9 posts down...
Edited 1 time(s). Last edited Tuesday, October 31, 2006 3:02 PM
Sunday, November 12, 2006 11:10 PM
If Alpine, use a PAC model PAC 10 converter. It tricks the system into thinking the car is parked and comes with instructions. Of coarse, I'm not telling this so you can drive and watch it at the same time but, your passengers will be able to. Original Alpine CVA 1000 use the rca adapter cord, wire the park brake to a ground and hook the navigation in and out wires together....I know this works because I used to have this deck.
Monday, November 13, 2006 8:34 PM
for newer alpines, grab yourself a TR-7 module
