Built a box this weekend and it didnt fit into the trunk(would have fit inside just couldnt get it in.) So I need a fairly large box like 4cuft to house two 12"s so if anyone has a box they built could you give me the dimensions so I know what will fit. Tried measuring but theres so many factors on if it will or wont fit. Any opinions?
stick it in through the backseat
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
tried that but it is to long to get to turn it especially with the diagonal pieces behind the back seat(under the panels) so Im just gonna build a new one tomorrow. Just looking at what size I should do.
just cut em out, it'll allow for a 4 cubic foot box easy...although i slid a 4 cubic foot box with a port in through the seats without cutting....but i'd suggest cuttin em out, they're useless
LOL
yes, cut those out. You can fit a 36" wide box, and around 16-17" tall, depth is only limited by what you can cram through your door, lol
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
I fit a box 36x17.5x24 in there through the back seat
why you making the box so big????
did you get the correct dimension required for that sub???
becasue making a big box doesn't help your sound it makes it worse...
"Silver 2001 Cavalier z24 5 speed 2 door sunroof and power everything "
AEM Short Ram Intake
B&M Short Throw Shifter
if you read what I said... I basically said the same thing as you...
If you make a box bigger than your subs specs, it will sound off
n8ball2013 wrote:I fit a box 36x17.5x24 in there through the back seat
same here but only 16.5" high everything else the same
outcasts
Most of my boxes for probably 90% of my subs have been bigger then spec. They didn't sound off.
Mike Roth
