i moved my subs into the back seat for more sound and now the subs arnt working properly, there is no bass and it sounds hollow. i checked all the connections, tried another amp and nothing
Put em back in your trunk facing the rear and see if they are actually "broken." They probably just aren't sounding right because they aren't where they need to be. The trunk is where they should go.
Sold 6/30/06.
you were getting cancellation.
subs sitting on the seat = bad idea....not only for sound, but if an accident happens. thats alot of weight that will crush you.
Elemental Designs
Performance.Mobile.Audio.
alexl@edesignaudio.com
Warehouse Manager
yea i put them back in the trunk sounds better, but still not the same
You have some wires switched?
Lanman31337 - Cavfire wrote:You have some wires switched?
i agree
if when you moved them you mixed up polarity on 1 of the subs they will be out of phase and you will get cancellation. just double check your connections.
I checked it all again and its still the same my subs seem more mid ,high ranged now. i didnt disconnect any wires since ive moved them so it doesnt make sence unless the wires connecting the subs togoether has loosened but all 3 are working so im out of ideas
did you check crossover settings on the amp?? if your subs are putting out more mid and high sounds like the amp is not set to low pass.
