ok this so this is probably the most retarded thing i have ever seen in my life. i got this head unit from a friend who recked his car and i had to go buy a new harness for it but i didnt get the harness that hooks that harness to my stock harness. he said he would install it for me so the dumass cuts both harness and tries to splice them together(and fails miserably). so now i have a huge problem i need to find a factory radio harness so i can put my stock radio back in and so far the only thing iv come up with is the $500 whole dash harness. does anyone know where i can get just a stock radio harness?
just rewire it yourself not hard, lol look on the org here for a wiring diagram im sure you could find one!
Who needs a sig?
www.sinisterimages.com
i dont need to rewire it i need the plastic head of the harness that hooks into the radio it was cut off
You can try a GM05R which is the reverse harness from Scosche made for the Geo Tracker 2000+. Should work perfectly...
Corsica Dude wrote:You can try a GM05R which is the reverse harness from Scosche made for the Geo Tracker 2000+. Should work perfectly...
where would i get one of these
walmart should have it
Who needs a sig?
i dont think walmart will carry the reverse harness... Ide suggest going to a local stereo shop and see if they have one, like Scotty B said. Check the junkayr.
Elemental Designs
Performance.Mobile.Audio.
alexl@edesignaudio.com
Warehouse Manager
i went to a local junkyard and they hooked me up with one for $10 dollars
thanks for the input.
